TwinTurbo.NET: Nissan 300ZX forum - power balance test
power balance test
zgene4
on November 08, 2011 at 1:56 PM
how can you tell when a coil pack goes bad???
posted by GitNMyBelly
on November 08, 2011 at 01:29 PM
unplug the coil pack in question, any change to idle? Yes, coil is working. No, swap with known working unit.
WARNING: I lack industry backing
GitNMyBelly
13:29:00 11/08/11
power balance test -
zgene4
13:56:14 11/08/11
Re: power balance test
GitNMyBelly
13:58:37 11/08/11
cause it's probably your injector
zgene4
14:01:19 11/08/11
Re: cause it's probably your injector
Krazyd27
15:10:18 11/08/11
Krazyd27
15:10:49 11/08/11
Swap with another coil pack and see if it follows.
cherryz
14:38:45 11/08/11
What do nismo 555injectors ohm at? (n/m)
GitNMyBelly
17:51:50 11/08/11
healthy ones should be 10-14ohms - typically 10.9 ish (n/m)
21:54:03 11/08/11
dying injector. (n/m)
21:54:51 11/08/11
swapped out injector that read 30ohms. now other 2
GitNMyBelly
10:43:35 11/09/11
how can i test the signal going to the injectors? or what
GitNMyBelly
10:57:30 11/09/11
Ohm meter or spare inj hooked up but laying in your hand.
Woody75 (Denver)
12:49:51 11/09/11
injectors ohm 11.3-11.4... i spin the CAS and i connected
GitNMyBelly
12:44:52 11/11/11
